Ich hab die Seite von Solo-Moto mal durch den Babelfish laufen lassen.
"It is not necessary that you hope the Hall Paris to know how it will be new GSX-R 600. Here you have it, in primicia.
The first images of new and spectacular GSX-R 600 speak of total aesthetic renovation. For want of concrete engineering datas, we assured that in Hamamatsu one has worked to make his supersport one more aggressive. Its image follows patterns GSX-R, although it separates clearly of the great GSX-R of a liter of piston displacement. The frontal, the fairing and the quiet one of escape are the three differentiating characteristics of the new GSX-R, as well as the areas that more variations have suffered.
The fairing is totally new, although their forms of family are conserved, like the height of their transparent cupola. The lateral openings stay, col?n now more is sharpened and incorporates a later pilot of new diodes LED.
Its frontal is characterized by a new triple optics - something convex towards ahead -, with elipsoidal center and two multiconvex, of great size. Under the light two enormous entrances for the system of forced air admission are located, which indicates a clear preoccupation to obtain to a high number of Maxima power, that surely already will surpass 130 cv. The quiet one of escape returns to change and happens to be more voluminous and it is extended backwards, in search of the sufficient volume to lodge the catalyst and to obtain a low level of decibels. A return to the origins, but with rectangular forms."
demnach bekommt die "NEUE" auch einen neuen Scheinwerfer mit 3! Lampen. Schaun wir mal, ob sie denn wirklich so kommt. War heut nochmal bei meinem Dealer, ihm ist keinerlei Information von Suzuki bekannt, dass die 600/750 er ?berarbeitet werden soll. Was ihn allerdings auch stutzig macht, dass es das erste Mal w?re, dass der 2-j?hrige Update-Zyklus nicht eingehalten wird....
Hier noch eins gefunden:
